2023-05-22 12:15 AM
Developing complex applications can be tricky, often with pages stuck for several minutes
2023-05-22 4:57 AM
Hello @Hhuan.3,
Could you be more specific on what you wanna do in your application ?
How many and which widgets do you want to use on your screens ?
Also, for your information, we did big improvements on the way we handle widgets resources management inside large applications, in the latest versions of TouchGFX. So I'll encourage you to use the latest version (currently 4.21.4), and let me know if it solves your lag issue.
/Yoann
2023-05-22 4:57 AM
Hello @Hhuan.3,
/Yoann
2023-05-22 7:50 PM - edited 2023-11-20 4:57 AM
4.20.0 has been updated to 4.21.4, there is a problem in the picture, may I ask what needs to be changed?
2023-05-22 8:34 PM
touchgfx:paint:tearDown(); Trying to add a definition doesn't work either
2023-05-23 3:33 AM
Problem solved
