2020-07-25 12:51 PM
I am getting a issue with simulating touchgfx projects. These are the steps I followed.
I am getting this error when i try to simulate.
Run Simulator
Generate
Done
Generate Assets
make -f simulator/gcc/Makefile assets -j8
generated/simulator/gcc/Makefile:215: recipe for target 'images' failed
process_begin: CreateProcess(NULL, ../Middlewares/ST/touchgfx/framework/tools/imageconvert/build/win/imageconvert.out -r assets/images -w generated/images, ...) failed.
make (e=2): The system cannot find the file specified.
make[1]: *** [images] Error 2
simulator/gcc/Makefile:32: recipe for target 'assets' failed
make: *** [assets] Error 2
Failed
Failed
This is my git ignore.
/Debug/
/Release/
/TouchGFX/build/
/Middlewares/ST/touchgfx/lib/
/TouchGFX/generated/
/TouchGFX/simulator/msvs/.vs/
/.settings/
*.vcxproj.filters
*.VC.db
*.VC.opendb
2020-07-27 12:13 AM
If I remember correctly, I had to un-ignore the imageconvert.out and fontconvert.out files inside the /Middlewares/ST/touchgfx/framework/tools/...convert/build directory.
# but do NOT ignore these files!
!imageconvert.out
!fontconvert.out
...But my .gitignore is purely based on filetypes, so your mileage may vary.
2023-07-26 3:31 AM
Hello @Kasun Dinesh
I have run into a similar issue and was wondering if you were able to fix this?
2024-02-07 1:54 AM
I know it has been a while since you raised this query. I encountered a similar issue and renaming my project to a smaller name worked for me.
I hope this solution helps someone else facing a similar problem.
2024-02-07 2:46 AM
Hello @MVagh.2 ,
Thank you very much for sharing your solution. I'll close this thread since it has been open for 4 years now. If anyone is facing this issue again, please start a new thread in the community, we'll see what we can do.
2025-12-22 8:26 AM
I'm having the same issue.
Shouldn't imageconvert.out and fontconvert.out generated by TouchGFX when generating the code?
