touchGFX function startMoveAnimation is leaving dots in the path. why ?
Eblec.1
17 REPLIES 17
Osman SOYKURT
Hello Eblec.1,
Ok, and what did you put for dimensions of your application on TouchGFX Designer ? 240*240 or 320*240 ?
Also did you modify the dimension of your display with STM32CubeIDE ?
/Osman
Osman SOYKURT
Eblec.1
Hello, Oskt.
I declared the 320 width, 240 height in stm32cubemx for software-packs / touchGFX / display.
I didn't see any other place to set this.
in touchGFX config / display I see it as W 320 * H 240.
I didn't look for it in the IDE.
thanks. eyal.
Osman SOYKURT
Hello Eyal,
Indeed that would be enough. And what is the "Display Interface" configuration you have on STM32CubeMX ? LTDC, FMC ?
/Osman
Osman SOYKURT
Eblec.1
hello, Oskt.
I set the display interface to Custom and added the file I have from the screen manufacture : st7789.c & .h .
Eblec.1
I made changes to touchGFXHAL.cpp : copyFrameBufferBlockToLCD & flushFrameBuffer functions,
to be compatible to the st7789 I use.
Osman SOYKURT
Hello Eyal,
Have you tried to use other animations like screen transitions, fadeAnimation, changing box/screen color etc...
/Osman
Osman SOYKURT
Eblec.1
hello, Oskt.
No, I didn't !
Osman SOYKURT
Ok, try with that, it will help us to see if it's a bug related to the animations or the screen itself.
Also, we have an article to check the display screen, you can have a look and try the example with changing the screen color.
/Osman
Osman SOYKURT
