2021-08-24 11:25 PM
I would like to use one Dynamic Graph in Wrap Overwrite behavior and display two waveforms, one on the top half and two on the bottom half simultaneously. But could not find any waveform addition feature in Dynamic Graph?
How to do that ?
2021-08-29 5:35 PM
Hello YSN,
To create multiple waveforms, you need to stack multiple Dynamic graph widgets.
One widget will only display one waveform.
Hope it helps,
/Alexandre
2021-08-29 5:35 PM
Hello YSN,
Hope it helps,
/Alexandre
2021-08-30 12:28 AM
Okay, Yes it helped me. ! Thanks
