Touchgfx Designer is not opening in the computer.
MPath.4
 last time also this problem was occured so I installed it again after that it run for some days now again the problem has occured.
 When I open Touchgfx one msg come
Sorry - something unexpected has happened which caused an error to occur in the Designer.
For more information, see the log file located at: C:\Users\Kaushal\AppData\Roaming\TouchGFX-4.21.3\TouchGFXDesigner.log
Please someone help to give the solution of it.
25 REPLIES 25
OWLchan
​i have same problem with u
​when i using demo
when i trying Generate Code, run simulator and run target has same this error
Generate Code
  Copy Framework
    Copying TouchGFX framework version 4.21.3 to C:\Users\GIANG\Documents\TOUCH_GFX\MyApplication_5\Middlewares\ST\touchgfx
    Done
  Generate
    Wrote config/gcc/app.mk
    Wrote config/msvs/Application.props
    Wrote generated/gui_generated/include/gui_generated/common/FrontendApplicationBase.hpp
    Wrote generated/gui_generated/include/gui_generated/common/FrontendHeapBase.hpp
    Wrote generated/gui_generated/include/gui_generated/common/SimConstants.hpp
    Wrote generated/gui_generated/include/gui_generated/screen1_screen/Screen1ViewBase.hpp
    Wrote generated/gui_generated/src/common/FrontendApplicationBase.cpp
    Wrote generated/gui_generated/src/screen1_screen/Screen1ViewBase.cpp
    Wrote generated/simulator/gcc/Makefile
    Wrote generated/simulator/include/simulator/mainBase.hpp
    Wrote generated/simulator/include/simulator/video/DirectFrameBufferVideoController.hpp
    Wrote generated/simulator/include/simulator/video/MJPEGDecoder.hpp
    Wrote generated/simulator/include/simulator/video/SoftwareMJPEGDecoder.hpp
    Wrote generated/simulator/msvs/touchgfx_prebuild.targets
    Wrote generated/simulator/msvs/touchgfx_sdl2.props
    Wrote generated/simulator/msvs/touchgfx.props
    Wrote generated/simulator/src/mainBase.cpp
    Wrote generated/simulator/src/video/SoftwareMJPEGDecoder.cpp
    Wrote generated/simulator/touchgfx.ico
    Wrote generated/simulator/touchgfx.rc
    Wrote generated/simulator/touchgfx.res
    Wrote generated/user.config
    Wrote gui/include/gui/common/FrontendApplication.hpp
    Wrote gui/include/gui/common/FrontendHeap.hpp
    Wrote gui/include/gui/model/Model.hpp
    Wrote gui/include/gui/model/ModelListener.hpp
    Wrote gui/include/gui/screen1_screen/Screen1Presenter.hpp
    Wrote gui/include/gui/screen1_screen/Screen1View.hpp
    Wrote gui/src/common/FrontendApplication.cpp
    Wrote gui/src/model/Model.cpp
    Wrote gui/src/screen1_screen/Screen1Presenter.cpp
    Wrote gui/src/screen1_screen/Screen1View.cpp
    Wrote simulator/gcc/Makefile
    Wrote simulator/main.cpp
    Wrote simulator/msvs/Application.sln
    Wrote simulator/msvs/Application.vcxproj
    Wrote simulator/msvs/Application.vcxproj.filters
    Wrote target.config
    Done
  Generate Assets
    make -f simulator/gcc/Makefile assets -j8
    Reading ./application.config
    Reading ./target.config
    Generating generated/images/include/BitmapDatabase.hpp
    Generating generated/images/include/images/BitmapDatabase.hpp
    Generating generated/images/src/BitmapDatabase.cpp
    Generating generated/images/include/images/SVGDatabase.hpp
    Generating generated/images/src/SVGDatabase.cpp
    C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/3.0.0/win32/registry.rb:910:in `encode': code converter not found (UTF-16LE to Windows-1258) (Encoding::ConverterNotFoundError)
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/3.0.0/win32/registry.rb:910:in `export_string'
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/3.0.0/win32/registry.rb:611:in `each_key'
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/site_ruby/3.0.0/ruby_installer/runtime/msys2_installation.rb:62:in `block in iterate_msys_paths'
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/3.0.0/win32/registry.rb:435:in `open'
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/3.0.0/win32/registry.rb:542:in `open'
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/site_ruby/3.0.0/ruby_installer/runtime/msys2_installation.rb:61:in `iterate_msys_paths'
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/site_ruby/3.0.0/ruby_installer/runtime/msys2_installation.rb:89:in `msys_path'
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/site_ruby/3.0.0/ruby_installer/runtime/msys2_installation.rb:102:in `mingw_bin_path'
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/site_ruby/3.0.0/ruby_installer/runtime/msys2_installation.rb:112:in `enable_dll_search_paths'
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/site_ruby/3.0.0/ruby_installer/runtime/singleton.rb:27:in `enable_dll_search_paths'
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/3.0.0/rubygems/defaults/operating_system.rb:3:in `<top (required)>'
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/3.0.0/rubygems.rb:1348:in `require'
     from C:/TouchGFX/4.21.3/env/MinGW/msys/1.0/Ruby30-x64/lib/ruby/3.0.0/rubygems.rb:1348:in `<top (required)>'
     from <internal:gem_prelude>:2:in `require'
     from <internal:gem_prelude>:2:in `<internal:gem_prelude>'
    make[1]: *** [texts] Error 1
    generated/simulator/gcc/Makefile:225: recipe for target 'texts' failed
    make[1]: *** Waiting for unfinished jobs....
    make[1]: *** [videos] Error 1
    generated/simulator/gcc/Makefile:229: recipe for target 'videos' failed
    simulator/gcc/Makefile:32: recipe for target 'assets' failed
    make: *** [assets] Error 2
    Failed
  Failed
Weird, that does not happen for me with 4.21.3.
Could you please try with the new 4.21.4 we just released, and let me know how it is going ?
Thanks,
/Yoann
Yoann KLEIN
Jnevi.1
your file is full of zeros and not a valid .touchgfx file
MPath.4
hello, @Yoann KLEIN​ I think there is no generator available of touchgfx4.21.4 in stm32cubemx and I am finding an issue in sending data it is always going to hardfault handler can you please provide the generator of touchgfx.
Hello @MPath.4​,
You can manually install the generator, by following the steps described at the bottom of this post.
/Yoann
Yoann KLEIN
MPath.4
OK I got it, Thank you so much for helping.@Yoann KLEIN​
