2022-05-02 05:13 PM
I have already use designer 4.18 and 4.19.1 for same project.
The 4.18 used ram about 1000 MB . When I change to 4.19.1 , ram used to 4600 MB. sometime used to 7800 MB. Make my PC slow down.
How to solve this problem?
Thanks.
4.19.1 picture
4.18 for same project
2022-05-03 01:39 AM
Hello @achan.12 ,
Can you please share or describe your project ?
It will be quite hard to help you without more information.
Thanks,
/Yoann
2022-05-03 09:02 AM
Ask is about PC RAM not target then maybe better is change subject to too many PC RAM
Seems newer isnt better alltime
2022-05-03 05:12 PM
OK . I'll cahnge to subject.
Thanks.
2022-05-03 05:23 PM
I give some picture for Designer 4.19.1.
Pic 1: The Designer 4.19.1 standby and used PC Ram on PC.
2022-05-03 05:43 PM
The old designer 4.18.0 for same project.
2022-05-05 06:07 AM
Did you try to run your project with another computer ?
Can you also please share your project so we can test it ?
Thanks,
/Yoann
2022-05-05 06:50 AM
I tried this project with another computer and get the same result.
Project link: https://drive.google.com/file/d/1-JrBctIpUDJ8cb6QvBQfkUMbqi1ai7SV/view?usp=sharing
2022-05-06 12:52 AM
Thanks,
The file "CircularArray.hpp" is missing, then I can not run the simulator.
Can you make sure to include everything in the project and then share it again to me ?
/Yoann
2022-05-06 01:29 AM
Why you used the simulator?
The problem is only on Designer.
When you used designer and switch the screen then monitor the PC ram.
You will find the problem again.
