TouchGFX cube_programmer.mk project File template
Options
2022-07-15 6:57 PM
TouchGFX projects has a cube_programmer.mk in each project folder.
I have installed my CubeProgrammer in a different location to the default location in the cube_programmer.mk. I was wondering if the cube_programmer.mk is created on each project creation as part of the code within in the TouchGFX IDE or is it a file template which is copied from another location each time? I would like to change the master file so I do not have to change the project file each time.
Labels:
STM32CubeProgrammer
TouchGFX
1 REPLY 1
Options
2022-07-16 1:00 AM
Maybe simpler is use MKLINK and create symlink on default place
