2020-11-10 08:54 PM
When the 16Bit Color Depth is set and the box color is set to 70,73,80 as the RGB value, the Box Color in the Visual Studio simulation is output as 66,73,82 as RGB values.
Since we are developing a product, we need to print the color set by the GUI designer as requested. Can you tell me the RGB range I can set?
@Martin KJELDSEN
2020-11-11 02:52 AM
I can confirm that there is a slight difference in colors. There will generally be a difference between what is rendered on Designer Canvas (.NET) and what is presented on the running simulator canvas (SDL2).
Ultimately, what is on your target should be correct, according to your settings. I'll investigate .
/Martin
2020-11-11 05:03 PM
Actually, my development environment is 800x480 TFT Color LCD and is controlled by TTL RGB. We look forward to your quick reply.
