TouchGFX 4.20.0: Import of Custom Container
awiernie
Senior II
I wanted to import a custom container from another project. It however does not work because typographies and images are already present in the current project. I use the same buttons in several custom containers and screens. In this case it should be possible to continue to import by using the already present resources.
4 REPLIES 4
awiernie
Senior II
Here is the log:
Prepare Import of package
  Validate package
    Package valid for import.
  Create import report
    Found Custom Container: CustomContainerStatusbar_1
    Found Text: __SingleUse_U8WM
    Found Text: __SingleUse_J454
    Found Text: __SingleUse_A8SL
    Found Text: __SingleUse_VEY1
    Found Text: __SingleUse_HHYW
    Found Text: __SingleUse_06GT
    Found Text: __SingleUse_I9NV
    Found Text: __SingleUse_T6YG
    Found Text: __SingleUse_SU1A
    Found Text: __SingleUse_5V1X
    Found Text: __SingleUse_K43U
    Found Text: __SingleUse_4AD2
    Found Text: __SingleUse_RPYU
    Found Text: __SingleUse_YLVU
    Found Text: __SingleUse_7IYM
    Found Text: __SingleUse_JL2B
    Found Text: __SingleUse_UB2E
    Found Text: __SingleUse_NX5W
    Found Text: __SingleUse_QAL6
    Found Text: __SingleUse_L20S
    Found Text: __SingleUse_DWC2
    Found Text: __SingleUse_36JK
    Found Typography Typography_05
    Found Typography Typography_MessageDetailAndTimer
    Found Typography Small
    Found Typography Typography_MeasDateTime
    Found Typography Typography_Statusbar
    Found File: gui/src/containers/CustomContainerStatusbar_1.cpp
    Found File: gui/include/gui/containers/CustomContainerStatusbar_1.hpp
    Found Image: radiobutton_no.png
    Found Image: radiobutton_yes.png
    Found Image: button_off_background.png
    Found Image: button_on_background.png
    Found Image: statusleiste_trennlinie.png
    Found Image: statusleiste_debugger.png
    Found Image: statusleiste_fehler_mur.png
    Found Image: statusleiste_hinweis_final.png
    Found Image: statusleiste_play_mur.png
    Found Image: statusleiste_measuring_mur.png
    Found Image: statusleiste_spuelvorgang.png
    Found Image: statusleiste_usb.png
    Found Image: statusleiste_download_final.png
    Found Image: statusleiste_upload.png
    Found Image: statusleiste_batterie_geladen.png
    Found Image: statusleiste_batterie_voll.png
    Found Image: statusleiste_batterie_laden.png
    Found Image: statusleiste_batterie_leer.png
    Found Image: statusleiste_aufwaermphase.png
    Found Image: statusleiste_aufwaermphase_2_mur.png
    Found Image: statusleiste_batterie_halb.png
    Found Image: statusleiste_hinweis_final_blue.png
    Found Image: statusleiste_fehler_final_red.png
    Found Image: spritzeyellow-24.png
    Found Image: air_mur.png
    Found Image: statusleiste_service.png
    Found Image: statusleiste_developer.png
    Found Image: poweroff20.png
    Found Image: transparent76x76.png
    Found Image: transparent400x40.png
    Found Image: hwbutton_power_80x80.png
    Found Image: hwbutton_home_80x80.png
    Found Image: hwbutton_back_80x80.png
    Found Font: AvenirNextW1G-Regular.ttf
  Scan for conflicts
    Typography with id: "Typography_05" already exists
    Typography with id: "Small" already exists
    Image: "radiobutton_no.png" already exists
    Image: "radiobutton_yes.png" already exists
    Image: "button_off_background.png" already exists
    Image: "button_on_background.png" already exists
    Image: "statusleiste_trennlinie.png" already exists
    Image: "statusleiste_fehler_mur.png" already exists
    Image: "statusleiste_hinweis_final.png" already exists
    Image: "statusleiste_play_mur.png" already exists
    Image: "statusleiste_measuring_mur.png" already exists
    Image: "statusleiste_spuelvorgang.png" already exists
    Image: "statusleiste_usb.png" already exists
    Image: "statusleiste_download_final.png" already exists
    Image: "statusleiste_upload.png" already exists
    Image: "statusleiste_batterie_geladen.png" already exists
    Image: "statusleiste_batterie_voll.png" already exists
    Image: "statusleiste_batterie_laden.png" already exists
    Image: "statusleiste_batterie_leer.png" already exists
    Image: "statusleiste_aufwaermphase.png" already exists
    Image: "statusleiste_aufwaermphase_2_mur.png" already exists
    Image: "statusleiste_batterie_halb.png" already exists
    Image: "statusleiste_hinweis_final_blue.png" already exists
    Image: "statusleiste_fehler_final_red.png" already exists
    Image: "spritzeyellow-24.png" already exists
    Image: "air_mur.png" already exists
    Image: "statusleiste_service.png" already exists
    Image: "statusleiste_developer.png" already exists
    Image: "poweroff20.png" already exists
    Image: "transparent76x76.png" already exists
    Cannot import package: There are conflict with existing items in project
    Package is not valid for import. View log for errors.
awiernie
Senior II
Maybe the reason is, that I have modified the conflicted items.
M.Gehrmann_bce
I have encountered the exact same problem.
It occurs with both the TouchGFX V4.20.0 and V4.22.1 that I tested.
Below is a simple example to reproduce it:
1) Create a new TouchGFX project
2) Create two simple custom containers
3) Export both custom containers
4) Create a new TouchGFX project
5) Import both custom containers
5.1) Works fine
5.2) Cannot be imported, typography DEFAULT already exists, pic.png already existing
Is there any workaround for this behavior?
The import function is completely useless for me in my project! And I have to create finished elements completely from scratch every time.
Hello @M.Gehrmann_bce ,
Thank you for your message. I'll check if we can prioritize a fix for resolving this issue. I'll get back to you when I'll have more info.
Osman SOYKURT
