TouchGFX 지�?하는 보드 문�?�
Sejinoh
안녕하세요
TouchGFX 사용 문�?� 드립니다.
제가 STM32F401RE 보드 사용중�?��?�, TouchGFX designer�?서는 해당 보드를 지�?하지 않는것 같습니다. ​
TouchGFX designer�?서 STM32F401RE 보드를 사용하는 방법�?� 있�?�까요?
5 REPLIES 5
Sean Park
Questions can be answered quickly by asking them in English. Korean questions are not used here.
First of all, if you are using NUCLEO-F401RE board, you have wrong MCU and board selection.
Among STM32 MCUs, you need to select an MCU with a Display Controller.
The STM32CubeMx tool makes it easy to select an MCU. And you have to choose a board for testing, you can check the ST evaluation boards there.
Thanks for your quick response.
I have one more question.​
Is there a way to support ​NUCLEO-F401RE board with any external display(lcd) on TouchGFX designer?
SPI Displays are your best bet.
https://www.youtube.com/watch?v=suMytEyQTP4
https://www.youtube.com/watch?v=HtnuMpVNHKc
Like the video above.
Search on YouTube for "Touchgfx SPI Displays".
Perfect!
I will try this one.
Thanks a lot for your reply
Hello @Sejinoh​
If you are satisfied with @Sean Park​'s answer, please close this request by choosing Select as Best.
Feel free to ask other questions on the community in English :)
/Alexandre
