2025-02-13 04:08 AM - last edited on 2025-02-13 04:16 AM by Andrew Neil
hello,
I Have linked the Touch GFX folder from another project and the code got compiled while running and Debug I am getting this error.
2025-02-14 05:53 AM
Hello @jijomathew ,
You should try debugging your application as suggested by @Andrew Neil .
By the way, I would not recommend to link your TouchGFX folder from another project because when you generate code in TouchGFX designer it's pointing to a specific folder (STM3CubeIDE folder) inside your application.
See below the lines when you generate code in TouchGFX Designer :
