Text View: double-click adjusts only one column
ferro
Senior III
Dear Gfx Team,
Could you please consider changing the following behaviour.
When in Text view and double click in any edge, adjust width of all columns - not just the one associated with that edge.
Example:
Intial widths
Double click on the boundry
... only the 1st columns adjusted
But, this is what should ideally happen after the double-click:
Thank you
Ferro
1 REPLY 1
LouisB
Hello @ferro ,
Thank you for your suggestion, I will talk with the team about this feature.
Louis BOUDO
