2024-05-22 4:14 AM
Dear Gfx Team,
Could you please consider changing the following behaviour.
When in Text view and double click in any edge, adjust width of all columns - not just the one associated with that edge.
Example:
Intial widths
Double click on the boundry
... only the 1st columns adjusted
But, this is what should ideally happen after the double-click:
Thank you
Ferro
2024-05-28 8:26 AM
Hello @ferro ,
Thank you for your suggestion, I will talk with the team about this feature.
