Successfully created a project STM32F469I DISCO AU1 but can't import to IAR
JGuo.5
When importing the project to IAR, a file STM32F469I-DISCO-REV-AU1.ipcf reported missing.
1 REPLY 1
LouisB
Hello @JGuo.5,
When you say import, you mean you open the .ewv file and tried to build the project ?
Have you done these steps :
  • Change the tool chain in CubeMX to EWARM
  • Generate code in CubeMX
  • Regenerate code in TouchGFX Designer
If you follow these steps you should have all the files generated.
I hope it helps,
Best Regards,
Louis BOUDO
