2020-11-14 8:12 AM
He
I'm sending the program.
I want to display min_current from main.c after pressing the START button in AreaMin instead of the min given by ButtonADD_MIN and ButtonSUB_MIN buttons
greetings
2020-11-17 5:55 PM
I'm very sorry, it is still not clear to me.
Could you try to add code snippets, images, anything visual that can help me figure out your goal and where exactly you struggle ?
This is also good practice for your next posts on the community :)
/Alexandre
2020-11-16 9:21 PM
Unfortunately, I don't understand your issue. Could you provide more information ?
/Alexandre
2020-11-17 2:31 AM
Hi
Alarm clock. I set the off time with the buttons. Another button sends the setting to main.c. After sending, I want the elapsed time to be shown instead of the set time. Now the set time overlaps with the current time here. Is it possible to implement?
best regards
Andrzej
2020-11-17 5:55 PM
/Alexandre
2020-11-17 11:29 PM
Hi
I will try to explain. For now, however, on trying, I have damaged the program and I have to recreate it.
best regards
Andrzej
