Tuoman
Senior II
April 15, 2020
setWideTextAction() not having desired effect
  • April 15, 2020
  • 5 replies
  • 1702 views
I try to use setWideTextAction() to wrap my long text into new lines as it goes over screen.
However, setWideTextAction does not seem to do anything.
What I have done:
-disable Auto-size and set text area size within screen limits (to generate code below)
-set Ellipsis character for this typography to *
-use code:
textPopup.setPosition(29, 0, 180, 160);
 textPopup.setColor(touchgfx::Color::getColorFrom24BitRGB(207, 207, 207));
 textPopup.setLinespacing(0);
 textPopup.setTypedText(touchgfx::TypedText(T_SINGLEUSEID228));
 textPopup.setWideTextAction(WIDE_TEXT_CHARWRAP);
 textPopup.invalidate();
 textPopup.resizeToCurrentText();
 textPopup.resizeHeightToCurrentText();
There is no ellipsis character, no newlines, the text just prints over the borders like it was not there.
How to use this?
Thanks!
Best answer by Martin KJELDSEN
You've just resized to Current Text, so naturally there won't be any wrapping. The textarea is now as long as the text and requires no wrapping.
/Martin
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
April 15, 2020
/Martin
Tuoman
TuomanAuthor
Senior II
April 15, 2020
Oh right, didn't realize that it will cut the text.
Thanks, just saved me many hours, worked immediately!
Martin KJELDSEN
Principal III
April 15, 2020
Awesome! :) No problem.
arnaljl
Good grief, I fell in this trap too ! :grimacing_face:
Thanks @Martin KJELDSEN​  ! 🤩
Martin KJELDSEN
Principal III
November 18, 2020
Haha. No problem. If there's a trap, then there's probably something to be improved.
