2020-05-29 7:41 AM
There is a "click" button on the screen. The status of this button is sent to the user program. There is a second "toggle" button on the screen. The first button must put the second button in a non-pressed state if it was depressed. the user program (main.c) must make the decision. How to do it?
2020-06-02 4:37 AM
Take a look at the webinar that is posted at the top of this forum as a sticky - Here i go through how to turn on an LED from the UI and how to trigger an animation in the UI using a physical button. The same would apply here, except you're sending a message out of the UI and into the UI again to enable the second button.
2020-06-02 5:04 AM
There is a problem with it in my case.
I have ButtonBack (toggle) and other buttons (toggle).
ButtonBack changes the screen.
I need to hurt the screen change where other buttons are attached. I tried in many ways but to no avail.
2020-06-02 10:38 AM
In the end I solved this problem by blocking the screen change button:
if (ButtonDown.getPressed () == true)
ButtonBack.setVisible (false);
else
ButtonBack.setVisible (true);
ButtonBack.invalidate ();
2020-06-02 11:22 AM
Okay, i completely misunderstood what you wanted to do :)
