Speed gauge
ÖDemi.1
Hello,​
When to add speedometer and pointer apps to touchgfx app
can you look at the link
https://www.syncfusion.com/blogs/post/speedometer-using-flutter-radial-gauge.aspx/amp
2 REPLIES 2
MM..1
Chief II
How is your question?
Martin KJELDSEN
Chief III
If you're asking how to ask add something like a speedometer, please check out the clock example from TouchGFX designer. You can just adapt it to show only one hand and modify the ranges and values to be that of a speedometer - That's pretty much what you want i think.
/Martin
