Slow SlideMenu transition on Graph
ALomb
I ported "Model UI TouchGFX Demo 1 " on my board (WaveShare Open746I).
Screen resolution increases to 1024x600 16BPP.
On the target and also slightly on the simulatorIn in the Graph screen transiton of SlideMenu it's very slow.
if I remove points and area setting the transition is less slow, until it becomes normal by removing the two graphs.
What this slowdown is due to ?
Also.
The addition of values to the graph is done in GraphView::handleTickEvent. How often GraphView::handleTickEvent is recalled? Depends on the screen resolution?
//Antonello
11 REPLIES 11
ALomb
Hi @Martin KJELDSEN​ ,
Sorry. I realized only now that I had not attached .ioc file
/Antonello
Hi, how did you make background dots (thought white ) in your screen?
Did you do it by major gridline?
