Share your Custom Widgets!
Juliette CRESPO
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import Custom Containers into different projects.
The TouchGFX team is working on developing new custom containers that could be useful for our own projects. You will find them under this post. The first widget is a keyboard. We hope that the idea will please you and that it will be useful for your projects ;)!
We invite you to do the same. In the guide attached you will learn how to create your own widgets and how to export them. We wish to create a space where the community can find and share custom widgets.
To keep this space a good place for collaboration between all of us, we invite you to share your project in a zip format which includes you widget (.tpkg) and a short document explaining your widget. Your post needs also to include at least one screenshot of your widget running on the simulator. Refer to the keyboard widget for an example.
Thanks for your contribution and have fun !!
/The TouchGFX team
37 REPLIES 37
Juliette CRESPO
Here is a zip file containing a guide and the keyboard custom container in the .tpkg format.
0693W00000UFIplQAH.png/Juliette
Sanchit1
Thank you so much!
Juliette CRESPO
Here is a zip file containing a keypad in .tpkg format and its guide.0693W00000UnEH9QAN.png
Juliette CRESPO
Here are different selectors: one for the date, one for the numbers and two for the time. This zip file contains the selectors in .tpkg format and a guide.0693W00000UnIpFQAV.png
Roger.ch
Hello Juliette.
Thank you for your keypad widget.
I have integrated it into a separate container.
Do you have any idea how I call a function of the parent container after the poundFlexButton is depressed?
Sequence:
The keypad is invisible.
When I press a button in my container the keypad becomes visible. Works.
When a string is entered the keypad becomes invisible again when the poundFlexButton is pressed. This works.
Now the parent container should realize that it can call the function Keypad::getText and take the text?
Can you give me a tip?
Best regards, Roger
JTP1
Lead
Hi Roger. Here is simple example how to get callback from keypad after pound is pressed.
Roger.ch
Hi JTP
Thanks a lot for your help.
Exactly what I was looking for.
You are saving my weekend right now.:grinning_face:
Have a nice weekend.
Best regards,
Roger
Hi Juliette.
Great!
Hello Juliette,
I would like to use your DatePicker Widget.
Is it possible to set the date, month, year programmatically in the same way as getday(), getMonth(), getYear() THANKS
