Seem that something on my Discovery board is going wrong..
How to flash original demo on STM32F469I-DISCO?
How to go successfull with examples on TouchGFX?
‎2020-12-07 9:58 AM
I bought a STM32F469-DISCO to start my adventure with STM's MCU.
Included demo is great.
Now I'm trying to upload some other example from CubeIDE and TouchGFX.
I've updated st-link, and go.. (I'm working on a windows 10 system)
From CumeIDE some examples for my Discovery board work fine. For example from CubeIDE -> new Project -> Example Selector -> StM32F469I-DISCO -> BSP and HID_RTOS are running fine.
From TouchGFX no example work on my board: Run Simulator go fine, Run Target get my board into black screen.
The strangest thing is that if I try to reload the original demo it don't work:
even if I flash the original HEX from https://www.touchgfx.com/resources/demos/
even if I run from CubeIDE -> new Project -> Example Selector -> STM32F469I-DISCO -> TouchGFX
The effect is like in the video attached: seem like something is going wrong on my device.
I suppose that the board is ok: It worked with original firmware, and it work with others examples from IDE.
But:
- how to run examples from TouchGFX?
- how to reflash original hex from touchgfx.com?
- Labels:
STM32F4 Series
TouchGFX
‎2020-12-07 10:02 AM
Try using STM32 Cube Programmer, and appropriate external loader for the F469I-DISCO
And reload the demo that came with the device.
https://www.st.com/en/evaluation-tools/32f469idiscovery.html
https://www.st.com/resource/en/compiled_demos/32f469idiscovery_demo.zip
‎2020-12-07 10:18 AM
Hi @Community member​ , thanks a lot for your support.
Great, that hex file in 1.2 vorsion work fine! The 1.3 no: it work similar to the video I've uploaded before.
How have you found it? :clapping_hands:
So, now I've to find the most important thing: make work with TouchGFX
‎2020-12-07 11:41 AM
Video is not viable on my Win 7 system. You'd do better with something in-line, or on YouTube.
There might be different versions of the board/screen, no way to make a determination from here. Could be a backlight or initialization issue.
‎2020-12-08 4:32 AM
Those are some pic of what happen if I run te TouchGFX demo from CubeIDE
After any reset pressure on the rear of the board the sequence could change... It's really strange.
In the other side, if I "Run Target" any example from TouchGFX the screen is alwais black. When I push the reset button 2 leds blink, and I can see the backlight that fade on. But nothing appear on the LCD
