SDRAM bad resolution on LCD
ssaeb
hello everyone
i have been working with a custom board F429IG
LTDC RGB565
SDRAM 32MB 16bit data width
STMCUBE IDE and CUBEMX 5.6
i have tested each hardware separately and they seem to work fine .
created a project to show just a button in 7" LCD 800X480 resoulotion
at first i programed the micro to use extrenal SDRAM as buffer but the picture went very bad0693W000000W3NbQAK.jpg
then i changed the SDRAM address from 0XC0000000 to internal address of 0X20020000 and i get this result which is perfect
here is 2 other pictures from 800x480 test in external memory
and my memory configuration
  /** Perform the SDRAM1 memory initialization sequence
  hsdram1.Instance = FMC_SDRAM_DEVICE;
  /* hsdram1.Init */
  hsdram1.Init.SDBank = FMC_SDRAM_BANK1;
  hsdram1.Init.ColumnBitsNumber = FMC_SDRAM_COLUMN_BITS_NUM_9;
  hsdram1.Init.RowBitsNumber = FMC_SDRAM_ROW_BITS_NUM_13;
  hsdram1.Init.MemoryDataWidth = FMC_SDRAM_MEM_BUS_WIDTH_16;
  hsdram1.Init.InternalBankNumber = FMC_SDRAM_INTERN_BANKS_NUM_4;
  hsdram1.Init.CASLatency = FMC_SDRAM_CAS_LATENCY_3;
  hsdram1.Init.WriteProtection = FMC_SDRAM_WRITE_PROTECTION_DISABLE;
  hsdram1.Init.SDClockPeriod = FMC_SDRAM_CLOCK_PERIOD_2;
  hsdram1.Init.ReadBurst = FMC_SDRAM_RBURST_ENABLE;
  hsdram1.Init.ReadPipeDelay = FMC_SDRAM_RPIPE_DELAY_0;
  /* SdramTiming */
  SdramTiming.LoadToActiveDelay = 2;
  SdramTiming.ExitSelfRefreshDelay = 7;
  SdramTiming.SelfRefreshTime = 6;
  SdramTiming.RowCycleDelay = 6;
  SdramTiming.WriteRecoveryTime = 5;
  SdramTiming.RPDelay = 2;
  SdramTiming.RCDDelay = 2;
  if (HAL_SDRAM_Init(&hsdram1, &SdramTiming) != HAL_OK)
    Error_Handler( );
  HAL_SDRAM_WriteProtection_Disable(&hsdram1);
    HAL_Delay(100);
    FMC_SDRAM_CommandTypeDef command;
    ///////////////////////////////////////////////////////////Clock
    command.CommandMode= FMC_SDRAM_CMD_CLK_ENABLE;
    command.CommandTarget= FMC_SDRAM_CMD_TARGET_BANK1;
    command.AutoRefreshNumber=1;
    command.ModeRegisterDefinition=0;
    HAL_SDRAM_SendCommand(&hsdram1, &command, 5000);
    HAL_Delay(10);
    ///////////////////////////////////////////////////////////Precharge
    HAL_Delay(100);
    command.CommandMode= FMC_SDRAM_CMD_PALL;
    HAL_Delay(10);
    ///////////////////////////////////////////////////////////SELF REFRESH
    command.CommandMode= FMC_SDRAM_CMD_SELFREFRESH_MODE;
    command.AutoRefreshNumber=10;
    HAL_Delay(10);
    ///////////////////////////////////////////////////////////MODE SETTINGS
    command.CommandMode= FMC_SDRAM_CMD_LOAD_MODE;
    command.ModeRegisterDefinition=0X00000133;
    HAL_Delay(10);
    HAL_SDRAM_SetAutoRefreshNumber(&hsdram1, 730);
My SDRAM is MT48LC16m16
i Think i am missing something but i cant figure it out
i am using no OS and tested the program with and without ChromeART (same result)
3 REPLIES 3
Basic SDRAM test (write some pattern into it and then read it back) without the whole video stuff, works?
yup that was a huge disaster , MODE setting should have been 0x130 , AutoFressh instead of SelfRefresh , and i am now getting the result i wanted took me 5 hours , thanks
HPATH.1
Hi @ssaeb, can you tell me which memory IC used for 32MB ?
