2023-04-01 06:46 PM
I am wondering if it is possible to implement a screenshot feature with TouchGFX. I want to capture the screen, in jpg or bmp format, and dump the image to serial for later viewing on computer.
2023-04-01 10:58 PM
There is nothing to do with TouchGFX. It just helps you to draw a picture on your screen by putting data in corresponding memory area. You have all data you need in the screen RAM (framebuffer) - just dump it to your serial.
If you need a BMP or JPG - I would suggest to write a converter on a PC rather than on MCU
2023-04-03 06:55 AM
Hi @BGuth.1
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Billy
