2022-11-30 4:12 AM
Hi everyone,
I need a function to draw many lines on runtime to show different work progresses. The lines should be able to be invisible and have 4 different colors.
When I would use the lines from TouchGFX it would generate a huge code to select the correct lines in the right colors.
Therefore I wanted to draw my own lines and add them at the place I need it.
I found this code below, but my code crashes after add(line1);
Any idea what I'm doing wrong
Line line1;
PainterRGB565 linePainter;
line1.setPosition(5, 125, 240, 1);
linePainter.setColor(Color::Color::getColorFromRGB(112, 146, 184));
line1.setPainter(linePainter);
line1.setStart(2, 0);
line1.setEnd(438, 0);
line1.setLineWidth(1);
line1.setLineEndingStyle(touchgfx::Line::ROUND_CAP_ENDING);
add(line1);?
Thank you very much
2022-11-30 7:11 AM
Is your framebuff RGB565? Where you place this code? Customize canvas buffer size for screen.
