problem with dynamic graph
mbagh.1
Hi, my problem is that when I use the dynamic graph, when it ends on the X axis, but unfortunately the X value increases How can I solve this problem and start the X axis again from scratch?
Alexandre RENOUX
Principal
Hello mbagh.1,
This request was already made in another post : https://community.st.com/s/question/0D53W00000etyKPSAY/how-to-make-fixed-xlabel-axis
Please before posting a question, try to make sure it was not already mentioned in the forum before. If you see a post or a problem that was already mentioned you can add a comment to it to show that you also have the problem. I'll close this post.
/Alexandre
Alexandre RENOUX
Principal
Hello mbagh.1,
/Alexandre
