Pressed button image
heyo
Is it possible to use bigger pressed button image than released button image? How can I achieve it?0693W00000UnwIaQAJ.png
Osman SOYKURT
Hello heyo,
Your two images needs to have the same size. If you don't have the same image size, you can create a new image with the dimension of your biggest image, paste your small image inside it, and fill the remaining area with transparency.
/Osman
Osman SOYKURT
15 REPLIES 15
Osman SOYKURT
Hello heyo,
/Osman
Osman SOYKURT
Thanks. Maybe do you have example of this?
I set button like this:0693W00000Uo3ELQAZ.pngPressed button shows how I want:
0693W00000Uo3FJQAZ.png But there is problem. I can't touch "6" button because "9" touch button area goes on "6"
Hello heyo,
Then you can restrict your touchable area by inserting your image in a container which is smaller.
Like this:
/Osman
Osman SOYKURT
Can u share this your project?
Sure here it is
/Osman
Osman SOYKURT
Thank you.
heyo
@Osman SOYKURT​  Hello again,
I have another problem. I do everything as you said but this happen:0693W00000Uo4arQAB.png0693W00000Uo4awQAB.png0693W00000Uo4b1QAB.png
If image size is bigger than container it does not show up. Do you have another solution?
