2026-05-13 1:17 AM
I have a flexButton in a View, and I want to execute different functions depending on whether the button is PRESSED, RELEASED, or CANCEL.
I know you can create interaction in TouchGFX Designer, but you can only call a virtual function on click. Is there a way to, for instance, enable the clickListener Mixin to read the event that has fired the callback from that specific button?
I need to read this event within the view and relative to my button.
Is there a way, or do I have to create a custom widget?
2026-05-13 5:59 AM
Ok, following this doc and using const touchgfx::ImageButtonStyle< touchgfx::ClickButtonTrigger >& button instead of const Box& b worked
2026-05-13 5:59 AM
