2017-12-17 2:13 AM
I am trying to interface 7' 800x480 TFT resistive touchscreen LCD based on SSD1963 using STM32F051R8T6( from the discovery). My aim is to write images onto an external NAND flash memory and read the images on to the LCD screen. The problem is the screen update rate(time required for screen fill) is very long about 3-5 seconds. I would like to have answers to my following queries:
1) What is the next best economic ST microcontroller that can give decent performance for my application(not directly going for the high end ones)?
2) What parameter of a microcontroller specs should be considered while selecting for GUI based applications?
Thanks.
#lcd #stm32 #nand #gui2017-12-17 2:19 AM
This was my work :
https://www.youtube.com/watch?v=j45JHzq7oNU
Same size screen, just OLED form HTC Desire. You will get only 10-15fps
2017-12-17 6:41 AM
Yikes! A STM32F051R8T6?
Does that even have an external bus for the NAND or Display Controller? Are you bit banging the interactions?
Consider an STM32 part that can manage the frame buffer and the display directly.
2017-12-17 11:06 AM
Thanks Linas. That was a good input. Did you use any driver for the graphics part? I have heard of chibios & ugfx.
Sent from Yahoo Mail on Android
On Sun, Dec 17, 2017 at 3:49 PM, karpavicius.linas<st-microelectronics@jiveon.com> wrote:
#yiv2164458148 * #yiv2164458148 a #yiv2164458148 body {font-family:Helvetica, Arial, sans-serif;}#yiv2164458148 #yiv2164458148 h1, #yiv2164458148 h2, #yiv2164458148 h3, #yiv2164458148 h4, #yiv2164458148 h5, #yiv2164458148 h6, #yiv2164458148 p, #yiv2164458148 hr {}#yiv2164458148 .yiv2164458148button td {}
Re: Need ST solution for interfacing 800x480 TFT LCD
reply from karpavicius.linas in STM32 MCUs Forum - View the full discussion
This was my work :
Smart Solder Reflow Oven Project - YouTube
Reply to this message by replying to this email, or go to the message on STMicroelectronics Community
Start a new discussion in STM32 MCUs Forum by email or at STMicroelectronics Community
Following Re: Need ST solution for interfacing 800x480 TFT LCD in these streams: Inbox
This email was sent by STMicroelectronics Community because you are a registered user.
You may unsubscribe instantly from STMicroelectronics Community, or adjust email frequency in your email preferences
________________ Attachments : Untitled.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyDz&d=%2Fa%2F0X0000000b4y%2FRcZ.2M3tumOmNe5_tuoNHD09GbDBL2gDFrP5ye7YyWc&asPdf=false2017-12-17 11:10 AM
Yes. I am considering a ST part that can manage both frame buffer and lcd directly. Great guide, gratefulfor your input.
On Sun, Dec 17, 2017 at 8:12 PM, Clive One<st-microelectronics@jiveon.com> wrote:
#yiv5722713094 * #yiv5722713094 a #yiv5722713094 body {font-family:Helvetica, Arial, sans-serif;}#yiv5722713094 #yiv5722713094 h1, #yiv5722713094 h2, #yiv5722713094 h3, #yiv5722713094 h4, #yiv5722713094 h5, #yiv5722713094 h6, #yiv5722713094 p, #yiv5722713094 hr {}#yiv5722713094 .yiv5722713094button td {}
reply from Clive One in STM32 MCUs Forum - View the full discussion
________________ Attachments : Untitled.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HyCE&d=%2Fa%2F0X0000000b4w%2FYS6DR6EOEMypFVzqyrpQRXxTayIyNXPBqBtZVCMiwgc&asPdf=false
