2021-06-08 4:22 PM
The following functions get blocked during application:
However, OSWrappers::signalVSync() works fine. The issue happens occasionally, most of the time, the TouchGFX GUI application is working fine.
What is the root-cause and how to debug / fix this issue?
Jianchun
2023-10-04 9:42 AM
We are also seeing something very similar with out UI task being blocked. The tick will not occur and ultimately the user says the device freezes. This seems to be very rare.
Our setup:
Was there a solution to this for this user? If so what was it?
If not do you have any good ideas on how to debug this scenario?
