Linker errors and "Run target" fails
2020-01-19 11:02 AM
hi everyone,
i wanted to create a project with touchGFX but there are errors, i just create the graphic interface, i didn't add any code!
even though when i tried to upload to my card an example it said error too!
how can i resolve this?
TouchGFX
2020-01-21 6:22 AM
@Martin KJELDSEN I thought about that too, but I tried I can't find this file or folder. I opened .map with vs 2019, I tried to find something but I can't find the mistake, here a copy of what i found in .map:
Archive member included to satisfy reference by file (symbol)
c:/st/stm32cubeide_1.0.2/stm32cubeide/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610/tools/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libstdc++_nano.a(pure.o)
Middlewares/ST/TouchGFX/touchgfx/framework/source/platform/driver/touch/ST1232TouchController.o (__cxa_pure_virtual)
c:/st/stm32cubeide_1.0.2/stm32cubeide/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610/tools/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libstdc++_nano.a(del_ops.o)
Middlewares/ST/TouchGFX/touchgfx/framework/source/platform/driver/touch/ST1232TouchController.o (operator delete(void*, unsigned int))
c:/st/stm32cubeide_1.0.2/stm32cubeide/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610/tools/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libstdc++_nano.a(del_op.o)
c:/st/stm32cubeide_1.0.2/stm32cubeide/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610/tools/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libstdc++_nano.a(del_ops.o) (operator delete(void*))
c:/st/stm32cubeide_1.0.2/stm32cubeide/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610/tools/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libstdc++_nano.a(eh_terminate.o)
c:/st/stm32cubeide_1.0.2/stm32cubeide/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610/tools/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libstdc++_nano.a(pure.o) (std::terminate())
c:/st/stm32cubeide_1.0.2/stm32cubeide/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610/tools/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libstdc++_nano.a(eh_unex_handler.o)
c:/st/stm32cubeide_1.0.2/stm32cubeide/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610/tools/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libstdc++_nano.a(eh_terminate.o) (__cxxabiv1::__unexpected_handler)
c:/st/stm32cubeide_1.0.2/stm32cubeide/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610/tools/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libstdc++_nano.a(eh_term_handler.o)
c:/st/stm32cubeide_1.0.2/stm32cubeide/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610/tools/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libstdc++_nano.a(eh_terminate.o) (__cxxabiv1::__terminate_handler)
I didn't add it i think, you can verify with this:
how & where I can find it to fix the error?
thank you
2020-01-21 6:37 AM
I found it i add it but it still the same error
2020-01-21 6:53 AM
@Martin KJELDSEN ,
I found the path and i added it, but still not working
2020-01-21 1:10 PM
Just created a project that links fine (CubeIDE 1.2.0)
* CubeMX Project Generator - Toolchain: CubeIDE
* Generate code
* Open part-file in TouchGFX Designer - Generate code
* Refresh project in CubeIDE and build
2020-01-21 9:21 PM
Hi @Martin KJELDSEN , the problem i’ve installed cubeIDE 1.2.0 but in middleware there’s no graphics any more, so can you tell me how to open touchgfx directly from CubeMX (execute : as the previous version), I have to select additional software then activate graphics touchgfx & then how to open touchgfx?
thank you
2020-01-22 12:21 AM
Please read the sticky on installing and using X-CUBE-TOUCHGFX 4.13.0. TouchGFX Graphics middleware is no more as of CubeMX 5.5.0 (it had too many restrictions on required hardware).
2020-01-22 1:28 AM
I read it @Martin KJELDSEN and did same, but no touchgfx folder is generated
and here I generated the code but no folder appears:
But I can't understand how to handle with those functions, it's very abstract
It will be very kind if you could guide me a more little bit
thank you
2020-01-22 4:18 AM
So you added TouchGFX Generator through additional software but you're not getting any options to configure? As far as i can tell from your screenshot. There should be!
/Martin
2020-01-22 4:24 AM
Which MCU is this for? For me, choosing STM32F746 i can add Generator in CubeIDE 1.2.0 and get the configuration window.
2020-01-22 5:16 AM
I use the same board f746G but why I can’t get the configuration window? I use cudeIDE 1.2.0 too! :thinking_face: did you add something in Cortex_M7 in system core @Martin KJELDSEN ? And in GPIO in system core too?
maybe I have to install something? No?
