2016-04-05 11:35 PM
When I try to draw JPEG�s I get a faulty display. MS_LoadFileIntoMemory(&fileNames[currentSel][0], arrayImagePreview1, MEMORY_SPACE_IMAGE_PREVIEW_1, USBH_Path, &realFileSizePreview1); prepareDrawPicture(); //For newXPos, newYPos, numeratorDraw, denominator GUI_JPEG_DrawScaled(arrayImagePreview1, realFileSizePreview1, newXPos, newYPos, numeratorDraw, denominator); int MS_LoadFileIntoMemory(char *fileName, char *fileBuffer, uint32_t fileSize, char* _Path, uint32_t* realFileSize) { uint32_t numberOfBytesRead; //Anzahl der tats�chlich gelesenen Zeichen uint32_t numberOfBytesToRead; //Anzahl der zu lesenden Zeichen int result; //Ergebniss der FAT Aktionen char file_path[MAX_FILENAME_LEN + 4] = ''''; //Pfad zur Datei, + SD_Path l�nge (''0:/'') + String End Zeichen FIL file; //Datei Handle //Fehlerpr�fungen assert_param(fileBuffer != NULL); assert_param(fileName != NULL); assert_param(fileName[0] != '\0'); assert_param(fileSize != 0); //Pfadt zusammenbauen //strcat(file_path, USBH_Path); //strcat(file_path, SD_Path); strcat(file_path, _Path); strcat(file_path, fileName); //Datei �ffnen result = f_open(&file, file_path, FA_OPEN_EXISTING | FA_READ); if (result != FR_OK) { GUI_DispString(fileName); GUI_DispString('' Open File...ERROR\n''); printf('' Open File...ERROR\n''); return -1; } //Komplette Datei auslesen. Falls die Datei gr��er als der //verf�gbarer Speicher ist, wird auf maximal m�gliche L�nge begrenzt numberOfBytesToRead = file.fsize; if (numberOfBytesToRead > fileSize) { numberOfBytesToRead = fileSize; } //Datei auslesen result = f_read(&file,fileBuffer,numberOfBytesToRead,&numberOfBytesRead); if (result != FR_OK) { result = f_close(&file); GUI_DispString(fileName); GUI_DispString('' Read File...ERROR\n''); printf('' Read File...ERROR\n''); return -2; } if(numberOfBytesToRead != numberOfBytesRead) { result = f_close(&file); GUI_DispString(''numberOfBytesToRead != numberOfBytesRead ...ERROR\n''); printf(''numberOfBytesToRead != numberOfBytesRead ...ERROR\n''); return -3; } if(realFileSize != NULL) { *realFileSize = numberOfBytesRead; } //Datei schlie�en result = f_close(&file); if (result != FR_OK) { GUI_DispString(fileName); GUI_DispString('' Close File...ERROR\n''); printf('' Close File...ERROR\n''); return -4; } return 0; } Does anyone have an idea where my mistake is? Thanks a lot Jens #stemwin
