2023-04-19 01:02 AM
Hello everyone,
I am working on a camera project, I am a beginner with STM32 and camera modules. I am using a MIPI module on Raspberry and I would now like to use it with an STM32, the problem is that with STM it is the DCMI protocol that is used. Could you tell me if you know of an existing component that allows the MIPI -> DCMI link?
Thank you in advance and have a nice day!
2023-04-19 01:24 AM
Hello @CCast.2 ,
I recommend you this Application Note : Introduction to digital camera interface (DCMI) for STM32 MCUs - Application note
Foued
2023-04-19 01:24 AM
Hello @CCast.2 ,
Foued
2023-04-20 12:53 AM
Hello @KHALSI_Foued,
Thank you very much for your answer, I will analyse this document and try to find solutions.
Have a good day !
Clément
2023-04-20 02:40 AM
If this solves your problem, please mark my answer as "Best Answer" by clicking on the "Select as Best" button, this can be helpful for Community users to find this solution faster.
Foued
2023-04-25 12:48 AM
I read the documentation and it was very helpful in my research.
I found a component allowing to make the transition MIPI -> DCMI : https://www.st.com/resource/en/application_note/an5470-stm32mp1-series-interfacing-with-a-mipi-csi2-camera-stmicroelectronics.pdf
But unfortunately there is no discovery board with a MIPI-CSI2 interface, if you have any ideas I'm listening.
Have a nice day!
Clément
2023-05-29 11:49 AM
Hey Clément!
Did you make any progress so far? Did you get the STMIPIDS02 running? I have the same problem as you 🙂
Best
Jonas
