how to remove unused graphic not referred in screens..
andrea venturi
hi,
slowly slowly i've got my growing TouchGFX project to become too fat for the2MB flash on a STM32F429..
as i've put too much graphic assets on the "database" and i'm not using all of them in the screens, i'm wondering if there's a way to find out "programmatically" which assets are not really referenced.. ( i know which "few" icons i put up with a routine..)
i only found this thread, 4 year old, that's really shows a manual procedure (and tedious..) =)
https://touchgfx.zendesk.com/hc/en-us/community/posts/207462585-Removing-unused-bitmap
thanx for hints!
Martin KJELDSEN
Chief III
There's no "tool" to do this if you're having a hard time getting an overview of unused assets, but if i have time i could write a script for you. Should be easy to do if you want to do it yourself. Hints:
  1. BitmapDatabase.hpp (generated in generated/images/include) contains all the bitmap ids
  2. Transform filenames (assets/images/) into IDs (e.g. BITMAP_BLUE_BACKGROUNDS_MAIN_BG_800X480PX_ID might be blue_backgrounds_main_bg_800x480px.png)
  3. Search all gui code (generated or otherwise) for references to the ids - If not found, add the filename to a list
  4. Delete all unused files contained in the list
  5. Re-generate assets (will clean up the bitmap database)
  6. Commit the removal of the assets from assets/images to your git repo
/Martin
4 REPLIES 4
Martin KJELDSEN
Chief III
/Martin
Martin KJELDSEN
Chief III
Here's some dirty Ruby-pseudo-code to get you started:
found = false
unused = []
pngs = Dir["assets/images/*.png"].collect {|a| "BITMAP_" + File.basename(a, ".png").upcase + "_ID" }
Dir["**/*View*.cpp"].each { |f|
	pngs.each { |p|
	  found = true if File.open(f).grep(/p/)
	unused << p if !found
        found = false
andrea venturi
than again Martin for the fast and constructive reply.. i'll try to make up something next days and report!
Sweet! Let me know how you do 🙂
