How to get Touch X and Y data ?
ihsanoglu
I need to get the X and Y coordinates of the touch controller and use them in Model or a View.
Is there a simple way to do this? (something in the API)
basically I want to get the x and y values returned from the sampleTouch() in TouchController class.
Martin KJELDSEN
Chief III
Implement the following virtual function in your view.
     * @fn virtual void Screen::handleClickEvent(const ClickEvent& evt);
     * @brief Traverse the drawables in reverse z-order and notify them of a click event.
     *        Traverse the drawables in reverse z-order and notify them of a click event.
     * @param evt The event to handle.
    virtual void handleClickEvent(const ClickEvent& evt);
The ClickEvent has the data you need.
touchgfx/events/ClickEvent.hpp
     * @typedef enum ClickEventType
     * @brief The click event types.
    typedef enum
        PRESSED,  ///< An enum constant representing the pressed option
        RELEASED, ///< An enum constant representing the released option
        CANCEL    ///< An enum constant representing the cancel option
    } ClickEventType;
private:
    ClickEventType _type;
    int16_t _x;
    int16_t _y;
Martin KJELDSEN
Chief III
    typedef enum
    } ClickEventType;
private:
    int16_t _x;
    int16_t _y;
Thank You!
