2024-10-24 7:44 AM
Hi there TouchGFX team!
I need to do a fade out animation when changing from my welcome screen to my home screen, but I can only see 4 options on TouchGFX designer.
I suppose I need to change the alpha value, but there's several widgets on each screen, so I'm not sure updating each one of those alpha values is the best approach.
How can I implement it?
Thanks a lot in advance
2024-10-25 5:00 AM
Hello @JPabl.1 ,
A previous answer suggested to fade in a black box before switching to the new screen and on the new screen having a black box fading out.
See the post here : https://community.st.com/t5/stm32-mcus-touchgfx-and-gui/screen-change-transition-options/td-p/120986
If this answers your question, I invite you to select this comment as "best answer".
2024-10-25 5:00 AM
Hello @JPabl.1 ,
