how to display the special symbol "<" ?
tliao.1
is there a way to show the "<" symbol on the screen? I used a wildcard and want the string show likes this "< <value> %", but the "<" symbol will never see, is someone knows how to do that?
4 REPLIES 4
MM..1
Chief III
when enter in Designer you can try <<
but in C++ simply use this char as any other.
Romain DIELEMAN
Honestly an easy way to do this would be to use two text areas where you put the "<" in one text area and "<value>%" in another :grinning_face_with_sweat:
/Romain
thanks, sounds good and I will seriously consider this way.
Why not one area with
<< <value>%
