How to create Progress Indicator as shown in the image
Iswarya
I would like to create progress indicator as shown in the attached image. Can you please help me, how to do that
Martin KJELDSEN
Chief III
Hi @Iswarya​,
Have you checked out the ProgressIndicator example available as a UI template from the designer?
Let me know!
Best regards,
Martin
Martin KJELDSEN
Chief III
I'm not sure what the red line is in your image. If it's a part of what you're trying to do, but if you check one of the circular examples, you'll see that you can "fill" each of the elements in your gauge by having a canvas element below an image with transparency in the areas you want to show.
If you check out the example it should become apparent.
Best regards,
Martin
