2019-12-09 06:31 PM
Beginner question here: The widgets that can be selected in TouchGFX designer have standard sizes (small, medium, large). How can i create a widget with a non-standard size? Is there an example for this?
2019-12-12 10:07 PM
I figured it out. There is actually an article about this in the knowledge base.
Eddy
2021-03-02 12:30 AM
Hi @Eddy V
I have this problem too.
could you please tell me which article is related to the issue??
thanks in advance
2021-03-02 06:17 AM
This question is quite old, TouchGFX has greatly changed since. What are you trying to do exactly ? What widget are you working with ? Here is a link to the official documentation, hope this will help you understand how to work with TouchGFX and the different widgets.
/Romain
