How to change font size gradually with animation during the runtime using touchgfx designer?
miresu
Hi
I'm trying to make a text that gets bigger automatically with smooth animation.
Is there any way to make it happen using touchgfx?
I tried, but I couldn't find a good way to implement it.
I tried to make two typed text (one bigger, one smaller), but switching these two seems too unnatural and awkward.
Is there any way to dynamically change font size with animation?
LouisB
Hello @miresu ,
Its not possible to change the size dynamically since the font is compiled, but you could try to use a bitmap image in a texture mapper, then you will be able to do the animation you want to.
BR,
Louis BOUDO
1 REPLY 1
LouisB
Hello @miresu ,
BR,
Louis BOUDO
