how modify TS sensivity threshhold on a STM32F746G-disco.
MVERC.1
3 REPLIES 3
FBL
Hello @MVERC.1​
You can check this application note AN4299 Improve conducted noise robustness for touch sensing applications on MCUs  section 5.5 Threshold adjustment
Hope it helps!
MVERC.1
Thank's for your help but I don't know what F5336 register I have to modify to increase TS sensivity threshold. In my application there is a glass to protect TS and I have to detect through this glass.
Best regards
Michel
Osman SOYKURT
Don't know if that could help but I've found another thread which is actually treating the same subject. You can try to contact the creator of this other thread to know if he has found a solution.
/Osman
Osman SOYKURT
