How do resolve the Bus fault error causing to hard fault interrupt? it is happening when using the DCMI with DMA in STM32H730
IDE: STM32 CubeIDE and for more details please check the attached USB_CAM pdf
particularly when i am using the DCMI with DMA
‎2021-05-10 1:59 AM
‎2021-05-10 3:26 AM
Did you check Configurable Fault Status Registers (CFSR) - 0xE000ED28? You should first check the registries to see a summary of the fault for better troubleshooting. If no, try UsageFault Status Register (UFSR) - 0xE000ED2A. If you want I can help you in a week after I return to my property in Larnaca
‎2021-05-10 3:32 AM
you can find the CFSR and HSFR register status in attached pictures
‎2021-05-10 9:40 PM
Is there any one to help me on this, want to solve above problem as soon as possible
Thanks in advance.
‎2021-05-12 12:29 AM
‎2021-05-12 12:31 AM
Please see the below Pictures and try to help me on this as soon as possible
