How can you copy screens from the simulator project to the select board setup project?
Nredd.1
HI,
I am using touch gfx designer 4.18.1, how to copy the screens my simulator project to board setup project, I did simulator project folder copy and paste in select board setup folder, then it shows an errors
MM..1
Chief III
Maybe you ask howto migrate GUI from simulator project , to project with target .
In menu is export import GUI try this.
