2020-08-03 5:41 AM
I am using the GUI on the top layer above live video and i must insert some box behind the widgets otherwise i got noise in the background on the top layer
2020-08-03 7:00 AM
@Alexandre RENOUX
By using color keying for the top layer
Mahmoud
2020-08-03 6:01 AM
Problem was solved
2020-08-03 6:57 AM
Good that you were able to solve it.
Could you explain how you solved it ? It might come useful for other people.
Thank you in advance :)
/Alexandre
2020-08-03 7:00 AM
@Alexandre RENOUX
Mahmoud
