How can I enable TouchGFX in STM32CubeIDE (STM32F429VI)?
gunnersson
My problem is simple, probably silly. I couldn't find any answer, even in other working projects from the net. I can't enable TouchGFX in Middleware (I can only enable STemWin Display Bus Interface using FMC). What am I missing:
2.Multimedia->DMA2D
3.Multimedia->LTDC
4.Computing->CRC
5.Middleware->FreeRTOS
And TouchGFX is still faded. What is wrong? I've checked DataSheet, Reference Manual, Errata, TouchGFX site, many other sites and somehow I am still missing something. Can you point my mistake?
1 REPLY 1
gunnersson
As I said, solution is simple. There's lack of D letter in SRAM. The IDE/CubeMX requires SDRAM, not SRAM. The F429 series can hold external SDRAM but not in LQFP100 package, changing to LQFP144 solved the problem. Now I need to change nearly whole layout - next time I'll read technical documentation more carefully.
Is there a way to configure touchgfx without external SDRAM through IDE/CubeMX?​
