Hi, I want to use a 4.5 digit non-multiplexed segmented LCD in static mode with STM32L053R8. But I can configure only 28 segments in STM32CubeMX. Can I use other four pins in manually ?
kaushikbm
If there is some other solution to it, apart from changing the uC, please suggest.
MM..1
Chief III
MM..1
Chief III
yes
Thank you MM for your quick reply :thumbs_up:
