Hi, I have a problem with communication between STM32F76ZGT and tft LCD using FMC.
A.W.
 All connections are correct but only the backlight is turned on. On another processor, the following code works fine. I attach the entire project and the display connection diagram. Thank you in advance for your help.
10 REPLIES 10
waclawek.jan
Read out and check content of relevant register, SYSCFG_MEMRMP.
Are you sure the connected LCD controller works as a static memory, i.e. that you can simply read back what you've written to it?
