2020-10-04 3:15 AM
And when I'm going to find the problems using DEBUG mode it gives me this error:
Cannot access Memory
*** error 122: AGDI: memory read failed (0xFFFFFFFE)
And this are is LTDC configuration and Clock configuration:
2020-10-13 9:45 AM
?? Frame buffer start address 0 ?? and why two layers
for your size and dot clock frame rate is 90Hz , isnt to big? Try change 12Mhz to 8MHz...
