2020-04-24 08:13 AM
searching on Internet I found the solution, that is to create a custom application template, but the link, https://touchgfx.zendesk.com/hc/en-us/articles/115002741432-Create-custom-Application-Template It still not available, so I'm looking for a new link with detailed documentation for create my custom application template
2020-04-27 06:52 PM
Hi @LMalv.1,
Also check out https://support.touchgfx.com/docs/development/touchgfx-hal-development/scenarios/scenarios-change-pixelformat-bpp
It shows what to consider when wanting to make changes to a TouchGFX project by reconfiguring the CubeMX project (like resolution, bit depth),
And the article for creating an application template is here: https://support.touchgfx.com/docs/development/touchgfx-hal-development/scenarios/scenarios-create-at
/Martin
2020-04-26 11:55 PM
Hi, please have a look at the Board Bring Up section in the new documentation. The How To sub section will guide you through the configuration steps to create your own application template for a custom board. This might be complicated and take you some time if you are new to this.
/Romain
2020-04-27 06:52 PM
Hi @LMalv.1,
/Martin
2020-04-28 12:35 AM
Thank you !!!
2020-08-24 01:41 AM
Hi Martin,
In the article for creating an application template,
" Open a TouchGFX Environment console and execute the following command in the parent directory of the application:"
2020-08-25 06:26 PM
I solved.
Everything is strange to a newbie.
