unsigned_char_array
Lead III
March 27, 2025
Feature request: Ability to hide blue border in editor
  • March 27, 2025
  • 4 replies
  • 1524 views
Currently the blue border masks the pixels on the edge so you cannot see what you are doing.
Example:
I want to be able to select and edit the widget while also seeing it completely.
I also want to be able to zoom in more than 500% and the ability to see a pixel grid. It's easy to be off by one.
(edit: removed section about scaling of the simulator window. Moved it to this topic: https://community.st.com/t5/stm32-mcus-touchgfx-and-gui/feature-request-integer-scaling-for-simulator-rendering/m-p/788659#M42727)
    GaetanGodart
    Hello @unsigned_char_array ,
    Thank you for your feedback, I will inform the team about your request.
    Gaetan GodartSoftware engineer at ST (TouchGFX)
    unsigned_char_array
    Lead III
    March 27, 2025
    "Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
    ferro
    Lead
    March 27, 2025
    very interesting, thanks
    GaetanGodart
    We will consider improving the selection for a future release.
