Don't know how to inherit handleClickEvent()
Iñaki_Bidasoro
Hi I have a scrollable container inside a swipe container and i need to check when the drag is horizontal and when it's vertical so that I can channel the event to the one i want it to handle with, this was discussed and resolved in this post:
https://community.st.com/t5/stm32-mcus-touchgfx-and-gui/swiping-and-scrolling/td-p/238053
But I have tried to implement it, changing the variable names but I have the following problems
  • Even though I have declared the classes in my view.hpp it says that the cpp cant see them, so i was wondering that maybe im doing it wrong, also i have tried to look for the functions in the upwards inheritance of the viewbase class but i couldnt find it, i saw that the classes like container do have it as they come from drawable.
  • the variable dragType is not found either, and this one I couldnt find anywhere, so maybe he created it but im not sure as it looks like a touchgfx variable.
This is how i have declared the functions in the view.hpp
class VacuumFunctionsView : public VacuumFunctionsViewBase
public:
    VacuumFunctionsView();
    virtual ~VacuumFunctionsView() {}
    virtual void setupScreen();
    virtual void tearDownScreen();
    virtual void customizeToggles();
protected:
    bool isListClicked;
    virtual void handleClickEvent(const ClickEvent& evt){}
    virtual void handleDragEvent(const DragEvent& evt){}
    virtual void handleGestureEvent(const GestureEvent& evt){}
And this is how i have implemented it in the cpp
void VacuumFunctionsView::handleClickEvent(const ClickEvent& evt)
    if (evt.getType() == ClickEvent::PRESSED)
        if(scrollProducts.getAbsoluteRect().intersect(evt.getX(), evt.getY()))
            isListClicked = true;
    else if (evt.getType() == ClickEvent::RELEASED)
        dragType = NONE;
    if(dragType != VERTICAL) //The swipe container should handle the event
        swipeContainer.handleClickEvent(evt);
    VacuumFunctionsViewBase::handleClickEvent(evt);
void VacuumFunctionsView::handleDragEvent(const DragEvent& evt)
    if(isListClicked)
        isListClicked = false;
        if(abs(evt.getDeltaY()) < abs(evt.getDeltaX()))
            dragType = HORIZONTAL;
        else
            dragType = VERTICAL;
    else
        if(dragType == HORIZONTAL) //The swipe container should handle the event
            swipeContainer.handleDragEvent(evt);
        else //The scroll container or the view should handle the event
            VacuumFunctionsViewBase::handleDragEvent(evt);
void VacuumFunctionsView::handleGestureEvent(const GestureEvent& evt)
        swipeContainer.handleGestureEvent(evt);
        VacuumFunctionsViewBase::handleGestureEvent(evt);
JTP1
Lead
Hello Iñaki
Its bit difficult to understand completely your problem, but lets try.
 Seems that you are allready defining functions to empty... test like this in .hpp:
    virtual void handleClickEvent(const ClickEvent& evt);
    virtual void handleDragEvent(const DragEvent& evt);
    virtual void handleGestureEvent(const GestureEvent& evt);
//Instead of
//    virtual void handleClickEvent(const ClickEvent& evt){}
//    virtual void handleDragEvent(const DragEvent& evt){}
//    virtual void handleGestureEvent(const GestureEvent& evt){}
For me it looks like just user-defined enumerated variable where dragging state is stored so I would add something like this to view.hpp
	enum dragTypeEnum
        NONE,
        HORIZONTAL,
        VERTICAL
	dragTypeEnum dragType=NONE;
 Maybe this helps you:thumbs_up:
Br JTP
2 REPLIES 2
JTP1
Lead
Hello Iñaki
//Instead of
	enum dragTypeEnum
        NONE,
        HORIZONTAL,
        VERTICAL
Br JTP
Thank you that was it!
